notification (by email) when tickets are created with a specific title
Kris Van de Vijver March 5, 2019
I'm trying to use the 'notification assistant' add-on to automatically send an email when a new service desk ticket is created with a specific title/summary. Although this seems basic, I can't find how to do this. I tried with a JQL Expression (summary is "blabla..") but I'm only getting a red message saying "Could not parse JQL query, you need to provide a valid JQL query."
Kris Van de Vijver March 12, 2019
I tried this but it didn't work..
Tom Lister
Hi
This a a bit odd
I can get the same error if I paste in
summary ~ “aanvraag Mac”
but
summary ~ “aanvraag” is OK
summary ~ “Mac” is OK
summary ~ 'aanvraag Mac' is OK
Nothing in the text search docs indicates why this error would occur.
Stumped!
Thanks Tom!
Tom Lister
Kris Van de Vijver March 6, 2019
Tried it all... nothing happens and I only see ..."Could not parse JQL query, you need to provide a valid JQL query.".. just below the JQL Expression box in the add-on.
Tom Lister
Is there a JQL Type field for Custom or Filter. Set to Custom JQL to enter an expression.
do you have a screen shot of the input and error
Tom Lister
Hi @Kris Van de Vijver
it won’t like the ‘try’ word. I’d didn’t mean that literally but I see my phrasing was misleading :-(
just use
Kris Van de Vijver March 7, 2019
Thanks for trying to help Tom. Tried your suggestion but again, the same message appears immediately : "Could not parse JQL query, you need to provide a valid JQL query."
Tom Lister
Try using the normal issue search filter creation screens to validate your JQL works.
Kris Van de Vijver March 11, 2019
A regular search through the normal Jira SD webinterface you mean?
This works, see screenshot.
Tom Lister
HI
yes - confirm your JQL is valid for a normal search
but does your exact syntax work
if so ,there is some other twist to the notification assistant.
If you save the above as a filter and use the filter option, does it work?
