Can I control the order in which epics appear in their list on the rapid board?
Thank you! Do you know how to order the versions? They appear to be in reverse order from what is in version admin
if you go to your version portion of the project page, you can grab the "handle" that is on the left of each version and move them around. this will, in turn, reorder them on the agile board.
You can. Simply drag and drop them into whatever order you prefer. At least I was able to do so in our instance using version 6.3.13.1.
