overriding permissions in transitions
francis
using the workflow transitions it is possible to disable commenting on an issue in certain statuses.
ie by putting jira.permission.comment.user = denied ...
Check the j-tricks blog on this subject
The disadvantage is that if the user wants to progress the issue to another status he/she will not be able to provide a comment (because the permission has been disabled)
Putting a transition specific permission (in the transition properties) doesn't do anything.
Any idea's how to fix this
RambanamP
July 1, 2013
you can try with Javascript,
add the following script in any field description on field configuraion of that issue type which is present on that transition by changing transition name on which you want hide the comment box
<script type="text/javascript">
jQuery(document).ready( function($) {
JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function(e,context) {
    callCommentHideFunction();
function callCommentHideFunction(){
    if($('#issue-workflow-transition-submit').val() =='working'){
        $(".wiki-edit").hide();     $("label[for='comment']").hide();
</script>
Florian Patzl July 1, 2013
No, but thank you for your quick response.
francis
Hello Florian,
We ended up allowing commenting, and autotransitioning the issue if a comment is provided. I guess this is no help for your case.
Hi Francis, did you find a solution to this issue? I'm having a similar problem, just concerning the 'assignee' field in my case. I'd like to prevent manual editing of the field in one workflow state but allow changing the assignee during a workflow transition.
Jobin Kuruvilla [Adaptavist]
October 4, 2012
You can't override what is on status with transition level properties. Can't think of a way to handle this!
Maybe try adding a custom field in the transition screen and copy its contents as comments in th post function or something!
Get Certified! ✍️
