overwrite web.xml and seraph-config.xml with atlas-run in order to test seraph SSO
Lloyd Meinholz March 19, 2014
I am developing a refapp plugin that uses seraph for SSO. I am trying to automate testing using the atlas-run command. Is it possible to overwrite the web.xml and seraph-config.xml that are used when starting the application this way?
Timothy
March 20, 2014
Not that I know off. Shutdown atlas-run, make the changes and execute it again.
Timothy
March 20, 2014
Really? I know I do that for my own JIRA instances.
LloydM March 25, 2014
Apparently something else was going on and things are working as you described. Thanks for your answer and response.
Miguel Mendez December 15, 2017 edited
I'm having the same issue.
I updated the `seraph-config.xml` in the target directory but then it says the class doens't exist and crashes. It seems to work fine if I place the jar manually but of course that means I can't use quickreload feature which slows everything down for development
LloydM March 20, 2014
This worked for Confluence, but not for Jira. It's less than an ideal situation anyway since I'm doing this to automate testing and now this would be a manual process. I'm wondering if there's some way to plug in to the process when the war is being assembled...
Thanks for the suggestion.
Help us plant more trees
