hi,
i have a projket with a issuetype and assoiciated screensheme/fieldconfiguration and Workflow.
To start a issue you can see an custom field configurated by schreensheme. The fieldconfig say, that this field is NOT REQUIRED.
But at on step in the workflow, you get a transition screen where this field schould be REQUIRED.
so is it possible to assign a new fieldconfig to this Transitionscreen?
can someone explain how it works, if possible.
You should use a validator to make a field required during a transition. But there is no such validator out of the box. You would need an add-on for it. Have a look at Jira Suite Utilities plugin, for example.
