×Hello Team,
im using the below code in post function of a transition to check if all the subtasks are in "Completed" status and to move the parent to "Completed".
however the code is not working .
can anyone please help me on this?
import com.opensymphony.workflow.WorkflowContext;
import com.atlassian.jira.config.SubTaskManager;
import com.atlassian.jira.workflow.WorkflowTransitionUtil;
import com.atlassian.jira.workflow.WorkflowTransitionUtilImpl;
import com.atlassian.jira.util.JiraUtils;
import com.atlassian.jira.issue.MutableIssue;
String currentUser = ((WorkflowContext) transientVars.get("context")).getCaller()
WorkflowTransitionUtil workflowTransitionUtil = (WorkflowTransitionUtil) JiraUtils.loadComponent(WorkflowTransitionUtilImpl.class)
MutableIssue parent = issue.getParentObject() as MutableIssue
if(parent){
passesCondition = true
def subTasks = parent.getSubTaskObjects()
subTasks.each{if(!(it.getStatus().name=="Completed"))
passesCondition = false
if (passesCondition) {
workflowTransitionUtil.setIssue(parent)
workflowTransitionUtil.setUserkey(currentUser)
workflowTransitionUtil.setAction(61)
if (workflowTransitionUtil.validate()) {
workflowTransitionUtil.progress()
...add logging to your script and find out what is happening ?
Where did you put this Post Function (before or after what other Post Functions ?)
