Hi @arno
The server hosting the Jira application does not have the Chinese font installed.
You may refer to the following document from Atlassian on resolving the issue. However, the steps might not cover the Chinese font.
Thank you.
thank you for your reply
you are right, my problem has been solved. Thank you for your help
