plugin for Jira
tolkit April 13, 2020
Hi! I am looking for a plugin \ extension for Jira. I need to duplicate the selected project with the ability to edit. CSV is not suitable for us to use.
Paloma Fondon Araujo
October 5, 2021
Hi @tolkit
With ScriptRunner there is an option to copy a project, it creates a new project, with the same configuration as the copied one, in addition, optionally you can also copy the issues, components, versions ...... I am not clear what you mean by what you want to edit, but you can choose the name and the key, and of course, configure it later according to the schemes you need to apply to it.
I hope that helps.
Best regards.
atlassian, social impact bingo, may it forward, atlassian foundation, community engagement, atlassian community events, atlassian learning, social impact challenge, volunteering, community kudos, atlassian social impact, atlassian community
Come one, come all!
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻‍♂️
