Do you have an idea of how to write a script to remove sprint fields for each created issue if IssueFunction in hasLinkType (cloners) ? I have chosen custom script post function but not sure about the code itself
Hi Ghazi,
So if you want to clean the sprint in "one go" you can run the following script in your script console
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.web.bean.PagerFilter
def issueManager = ComponentAccessor.getIssueManager()
def searchService = ComponentAccessor.getComponent(SearchService)
def customFieldManager = ComponentAccessor.customFieldManager
def jqlSearch = """
IssueFunction in hasLinkType ("Cloners")
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def issues = []
SearchService.ParseResult parseResult = searchService.parseQuery(user, jqlSearch)
if (parseResult.isValid()) {
def searchResult = searchService.search(user, parseResult.getQuery(), PagerFilter.getUnlimitedFilter())
issues = searchResult.issues.collect { issueManager.getIssueObject(it.id) }
//for all the issues returned from the JQL above clear the sprint field
issues?.each { issue ->
def sprint = customFieldManager.getCustomFieldObjectByName("Sprint")
if ( issue.getCustomFieldValue(sprint) ) {
def changeHolder = new DefaultIssueChangeHolder()
sprint.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(sprint), null),changeHolder)
Now if you want to cleat the spint from a sinlge issue during a tranisstion that you will need a custom script post function with the following script
// if that issue has at least one Cloners link then clear the sprint value
def hasCloner = ComponentAccessor.getIssueLinkManager().getLinkCollectionOverrideSecurity(issue).linkTypes*.name.contains("Cloners")
if (hasCloner) {
def sprint = ComponentAccessor.customFieldManager.getCustomFieldObjectByName("Sprint")
issue.setCustomFieldValue(sprint, null)
Thanos
