hi every one
i use nginx for revers proxy with the help of the link below
https://confluence.atlassian.com/jirakb/configure-jira-server-to-run-behind-a-nginx-reverse-proxy-426115340.html
but my gadget show __MSG_gadget name
I will be grateful if you can guide me
nginx.conf:
server {
listen 443 ssl;
server_name jira.[name].com;
ssl_certificate /etc/nginx/certs/jira.[name].com.pem;
ssl_certificate_key /etc/nginx/certs/jira.[name].com.key;
client_max_body_size 134217728;
access_log "/etc/nginx/Logs/1.log";
error_log "/etc/nginx/Logs/2.log";
root "<local_httpdocs>";
#extension letsencrypt begin
location ^~ /.well-known/acme-challenge/ {
root <local_htdocs>;
types { }
default_type text/plain;
satisfy any;
auth_basic off;
allow all;
location ~ ^/\.well-known/acme-challenge.*/\. {
deny all;
#extension letsencrypt end
#extension sslit begin
#extension sslit end
location / {
proxy_pass https://localhost:8080/;
proxy_hide_header upgrade;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
access_log off;
proxy_connect_timeout 180s;
proxy_send_timeout 180s;
proxy_read_timeout 180s;
fastcgi_send_timeout 180s;
fastcgi_read_timeout 180s;
}server.xml:
<Connector port="8080"
relaxedPathChars="[]|"
relaxedQueryChars="[]|{}^\`"<>"
maxThreads="150"
minSpareThreads="25"
connectionTimeout="20000"
enableLookups="false"
maxHttpHeaderSize="8192"
protocol="HTTP/1.1"
useBodyEncodingForURI="true"
redirectPort="8443"
acceptCount="100"
disableUploadTimeout="true"
proxyName="jira.[name].com"
proxyPort="443"
scheme="https"
secure="true"/>
Hi Sina,
That error message is mostly given when a Jira system can not reach itself over your network.
If you were to log into your Jira server and run something like "wget <base-url of your Jira>" it will return an error. This is a useful test actually, because it will give you the underlying error.
The three usual culprits are:
There's not really a single point to look into with this one, I've seen this couple times, some years back, I think it was solved a bit differently each time.
Take a look here: https://confluence.atlassian.com/jirakb/fix-gadget-titles-showing-as-__msg_gadget-in-jira-server-813697086.html
I'd suggest going through the list and checking things one by one, eventually something off that list should do it.
