Good afternoon.
Upgraded jira dc without me from 9.1.1 to 9.12.4 and the guys said some permissions message popped up and they ignored it.
now if I go to the Application Access tab there is nothing there.
so in any project, the permissions is empty.
everything is working, but I would like to fix it.
Has anyone run into this?
Hi @Buchelis_ Nikita ,
Have you managed to solve this issue please? If so, how?
We ran into exactly the same problem after updating Jira from 9.4.x to 9.12.13.
Any advice or hint would be appreciated.
So we figured it out, in our case it was the "Atlassian Hipchat Integration Plugin" which was blocking Application access and Project Permissions screens. Disabling it fixed the issue right away.
Good afternoon, on the test server all this was broken by the plugin "Time to SLA".
on prod server 9.12.4 hipchat.
Do you see any errors in either javascript or http requests when opening those pages?
I would expect there to be a 500 with either an error, or a more detailed error with stacktrace in atlassian-jira.log
Can't say I'd see this in particular before, but when pages fail to load there is typically a problem with the data being "loaded", such as unique key constraints, null pointers, etc. So based off that stacktrace we can probably figure out more.
Thank you for your reply.
I see only this warning in the logs when logging in to the Application Access page:
2024-04-03 15:02:49,699+0300 http-nio-8080-exec-9 WARN n.buchalis 902x45626x1 ikekmb 10.7.13.130,10.27.9.100 /secure/admin/ApplicationAccess.jspa [t.c.o.p.t.a.ao.timeInProperty.TimeInPropertyManagerImp] Multiple time in property objects found
when logging in to the permission page:
2024-04-03 15:05:07,734+0300 http-nio-8080-exec-26 WARN n.buchalis 905x45705x1 ikekmb 10.7.13.130,10.27.9.100 /plugins/servlet/project-config/XXX/permissions [t.c.o.p.t.a.ao.timeInProperty.TimeInPropertyManagerImp] Multiple time in property objects found
2024-04-03 15:05:13,059+0300 http-nio-8080-exec-9 WARN n.buchalis 905x45749x1 ikekmb 10.7.13.130,10.27.9.100 /rest/projects/1.0/sidebar/project/XXX [r.t.j.plugins.reminder.ReminderProjectTabPanel] tl rm panel showPanel: true : true : Project: XXX : ProjectTypeKey{key='software'}
2024-04-03 15:05:07,537+0300 pool-226-thread-1 ERROR [c.a.j.cache.request.RequestCacheRecorderImpl] Invalid use of RequestCache by thread: pool-226-thread.Incorrect usage of JIRA API. You can only create/use: RequestCacheImpl inside a context (request or Jira-Thread-Local). Check: JiraThreadLocalUtil for details. This message will be logged once per thread. This ERROR should be fixed on the caller side (check the stack-trace or thread-name) as it is causing inconsistent data.
java.lang.Throwable
at com.atlassian.jira.cache.request.RequestCacheRecorderImpl.errorLogOOCThreadUsage(RequestCacheRecorderImpl.java:32)
at com.atlassian.jira.cache.request.RequestCacheRecorderImpl.recordRequestCacheOOCUsage(RequestCacheRecorderImpl.java:25)
at com.atlassian.jira.cache.request.RequestCacheImpl.get(RequestCacheImpl.java:93)
at com.atlassian.jira.config.feature.DefaultFeatureManager.getDarkFeatures(DefaultFeatureManager.java:183)
at com.atlassian.jira.config.feature.DefaultFeatureManager.getDarkFeatures(DefaultFeatureManager.java:178)
at jdk.internal.reflect.GeneratedMethodAccessor328.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
at com.sun.proxy.$Proxy631.getDarkFeatures(Unknown Source)
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:130)
at com.atlassian.sal.jira.features.JiraDarkFeaturesManager.isFeatureEnabledForAllUsers(JiraDarkFeaturesManager.java:68)
at jdk.internal.reflect.GeneratedMethodAccessor909.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:344)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:137)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:124)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:241)
at com.sun.proxy.$Proxy2534.isFeatureEnabledForAllUsers(Unknown Source)
at com.atlassian.plugins.hipchat.api.DefaultHipChatDarkFeatureService.isInviteToHipChatEnabled(DefaultHipChatDarkFeatureService.java:25)
at jdk.internal.reflect.GeneratedMethodAccessor1751.invoke(Unknown Source)
at com.sun.proxy.$Proxy4070.isInviteToHipChatEnabled(Unknown Source)
at com.atlassian.plugins.hipchat.admin.ConfigureIntegrationDataProvider$1.call(ConfigureIntegrationDataProvider.java:59)
at com.atlassian.plugins.hipchat.admin.ConfigureIntegrationDataProvider$1.call(ConfigureIntegrationDataProvider.java:55)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
Hmm, well warning shouldn't be it but those pages don't use REST so maybe something using wrong log level internally could still be causing it.
Neither "t.c.o.p.t.a.ao.*" or "r.t.j.plugins.reminder.*" don't seem very native to me. Are those custom(user-installed) plugins? If so, can you try disabling them to see if the pages behave anywhere differently?
My first thought from this (and pretty much the only one without an actual error) is that some plugin could be doing something bad in the background. A plugin with key matching those packages most likely.
I turned off the reminder and the warning disappeared with it. But nothing changed in permission page.
applicattion access page
2024-04-05 09:59:13,067+0300 pool-240-thread-1 ERROR [c.a.j.cache.request.RequestCacheRecorderImpl] Invalid use of RequestCache by thread: pool-240-thread.Incorrect usage of JIRA API. You can only create/use: RequestCacheImpl inside a context (request or Jira-Thread-Local). Check: JiraThreadLocalUtil for details. This message will be logged once per thread. This ERROR should be fixed on the caller side (check the stack-trace or thread-name) as it is causing inconsistent data.
java.lang.Throwable
2024-04-05 09:59:13,117+0300 http-nio-8080-exec-18 WARN n.buchalis 599x48752x1 1vky7m2 10.7.13.130,10.27.9.100 /secure/admin/ApplicationAccess.jspa [t.c.o.p.t.a.ao.timeInProperty.TimeInPropertyManagerImp] Multiple time in property objects found
