I have been using profields, and just now upgraded to version 4. The problem is that i have already associated projects whith project field shemes, but the profields option in projet overview is missing.
I also see this string (shared by) in project sheme administrion:
In project navigator, i can see the fields with the values correctly!
Any ideas?
thanks
ok just solved it. In global configuration, the permissions drop-down was empty (which is valid because i want all groups to see project fields). I just selected another group, saved, and then re-selecte the empty option. Now works ok!
This was the solution for the missing project fields option in project overview.
Good news! If you still have the project overview problem, could you please create an issue in our online support(https://jira.deiser.com)? That way we can manage it better. Thanks a lot.
i installed the latest version and not only i still have the bug with the missing tab in project (as i expected) but the share projects bug is still there!
In the next few hours we'll release a new version that fixes the "Share projects" bug.
The "shared by" error will be solved in the next release, it is a minor bug, but this has nothing to do with the overview option. I don't know what is happening with the project webitem.
Do you have all the plugin modules enabled?
nothing in console and nothing obvious in atlassian-jira.log.
Do you have any error in the atlassian-jira.log?
When you go to Project Overview, do you have any error in the browser console?
