As Nik says, you can't have project keys starting with numbers by default. But there is an option to change it. You can modify the
jira.projectkey.patter property unde Administration > General Configuration Advanced Settings to include the numbers etc.
([A-Z0-9][A-Z0-9]+) might be enough to get you started with numbers but you might want to check for atleast one letter in it!
Good catch Jobin - I was thinking we were talking about OnDemand where access to that page/making that change is a restricted function.
Hi Jobin,
Thanks a lot . It worked :)
Best Regards
Fabio
glad it helped.
Nik, I didn't know Advanced Settings is restricted on onDemand. Thanks for pointing out :)
Unfortunately you cannot set up project keys with numbers. The full rules and guidelines for project keys:
You must specify a unique project key, at least 2 characters long, containing only uppercase letters.This is the unique project key. The project key:
* should be short and descriptive, as it prefixes each issue in the project;
* should not contain sensitive information, as it may be visible to users who do not have permission to view the project;
* cannot be changed once the project is created.
Hi Nik,
Thanks for the information.
Best Regards
Fabio
