publish workflow
Lynn Gariepy
January 12, 2014
Is there any danger to publishing a workflow that is assigned to a project during a workday?
Thanks, Lynn
Nic Brough -Adaptavist-
January 12, 2014
Not really - workflows you draft and publish can only really have their transitions changed, so the only thing you might run into is someone part-way through a transition having it change while they're doing it. Worst case is they get an error message and the transition doesn't complete.
Lynn Gariepy
January 12, 2014
Thank you!
