"Configuring Apache Reverse Proxy Using the AJP Protocol, " not working
Dear Team,
I am trying to create SSL for the Atlassian applications through apache.
I have followed all the steps which were mentioned in the KB article
https://confluence.atlassian.com/adminjiraserver074/configuring-apache-reverse-proxy-using-the-ajp-protocol-881684070.html
still, it's not working.
when I use HTTPS to the URL its not loading.
Please advise me
Many Thanks
IT- Admin
JP _AC Bielefeld Leader_
April 4, 2018
For convenience I post a stripped down configuration of our server:
First two files are Apache HTTPD configuration with mod_ajp. Third file is server.xml. We terminate SSL at the Apache HTTPD.
Jira is run on two ports: 8080 &8009
### File conf/extra/httpd-jk.conf
# Worker config
JkWorkersFile conf/extra/workers.properties
# Logging
JkLogFile logs/mod_jk.log
JkLogLevel warn
JkLogStampFormat "[%a %b %d %H:%M:%S %Y] "
#JkRequestLogFormat "%w %V %T"
# JkOptions indicates to send SSL KEY SIZE
JkOptions +ForwardKeySize +ForwardURICompatUnparsed -ForwardDirectories +RejectUnsafeURI
JkEnvVar httpd yourservername
# Mount on all vhost and ssl
JkMountCopy All
# redirect tomcat errors to apache httpd
JkMount /jira jira;use_server_errors=500
JkMount /jira/* jira;use_server_errors=500
# Modul (Admin)
JkMount /jk-manage/* jk-manage
JkMount /jk-manage jk-manage
# Enable the JK manager access from localhost only
<Location /jk-manage >
JkMount jk-manage
Require ip 192.168
Require ip 127
</Location>
### File conf/extra/workers.properties
# Global Settings
worker.maintain=30
# Default Settings
worker.basic.type=ajp13
worker.basic.socket_keepalive=true
worker.basic.ping_mode=A
worker.basic.ping_timeout=10000
worker.basic.connection_pool_timeout=120
worker.basic.recovery_options=7
worker.basic.lbfactor=1
worker.basic.max_packet_size=65536
worker.list=jira
worker.jira.host=ip.of.jira.server
worker.jira.port=8009
worker.jira.socket_timeout=300
worker.jira.socket_connect_timeout=300000
worker.jira.reference=worker.basic
# JK Manage Application
worker.list=jk-manage
worker.jk-manage.type=status
### server.xml
<?xml version="1.0" encoding="utf-8"?>
<Server port="8005" shutdown="SHUTDOWN">
<Listener className="org.apache.catalina.startup.VersionLoggerListener" />
<!--APR library loader. Documentation at /docs/apr.html -->
<Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" />
<!-- Prevent memory leaks due to use of particular java/javax APIs-->
<Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
<Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
<Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener" />
<Service name="Catalina">
<Connector port="8080"
maxThreads="150"
minSpareThreads="25"
connectionTimeout="20000"
enableLookups="false"
maxHttpHeaderSize="8192"
protocol="HTTP/1.1"
useBodyEncodingForURI="true"
redirectPort="8443"
acceptCount="100"
disableUploadTimeout="true"
bindOnInit="false"/>
<Connector port="8009"
minSpareThreads="10"
maxThreads="200"
address="your.jira.server.ip"
protocol="AJP/1.3"
redirectPort="8444"
URIEncoding="UTF-8"
maxPostSize="-1"
packetSize="65536"/>
<Engine name="Catalina" defaultHost="your.server.name" jvmRoute="jira">
<Host name="your.server.name" appBase="webapps" unpackWARs="true" autoDeploy="true">
<Context path="/jira" docBase="${catalina.home}/atlassian-jira" reloadable="false" useHttpOnly="true">
<Resource name="UserTransaction" auth="Container" type="javax.transaction.UserTransaction"
factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60"/>
<Manager pathname=""/>
<JarScanner scanManifest="false"/>
</Context>
</Host>
<Valve className="org.apache.catalina.valves.AccessLogValve" resolveHosts="false"
pattern="%a %{jira.request.id}r %{jira.request.username}r %t &quot;%m %U%q %H&quot; %s %b %D &quot;%{Referer}i&quot; &quot;%{User-Agent}i&quot; &quot;%{jira.request.assession.id}r&quot;"/>
</Engine>
</Service>
</Server>
Vickey Palzor Lepcha
April 3, 2018
@Patrick Kyne The serverl.xml has a line on ajp connectivity and the specific ajp port - uncomment it to enable it.
And on your apache ssl config file - add your ajp configurations specifying ajp port as it is in server.xml.
Patrick Kyne April 4, 2018 edited
I believe so and have my current configs here:
https://community.atlassian.com/t5/Jira-questions/Jira-Software-7-8-1-w-Apache-2-4-Reverse-Proxy-Errors/qaq-p/762699
Do they appear correct to you, or am I missing something?
April 4, 2018
@Patrick Kyne Have you tried ;
 ProxyPass               /     ajp://127.0.0.1:8009/      instead ?
I have not tried that because I access Jira via a URL like https://myhost.mydomain.fqdn/jira
and believe the ProxyPass would need to be
ProxyPass  /jira ajp://127.0.0.1:8009/jira
Are you suggesting I add an additional ProxyPass line?
JanR
You have to configure the connector to listen on the AJP port 8009. Are you using the mod_proxy or mod_ajp module on the Apache server?
I can asure you that Confluence, Jira, Bitbucket & Fisheye are working behind a single Apache server terminating SSL using AJP protocol.
Patrick Kyne April 3, 2018
I also am having issues with the ajp protocol using mod_ajp in Apache 2.4 connecting to Jira 7.8.1 on the same linux host as Apache.
Would you be so kind as to post the requisite sections of a working vhost.conf and your server.xml files (obfuscated as necessary).
Thank you,
Patrick
April 4, 2018
We‘re using mod_ajp not mod_proxy_ajp, so I can‘t give you any advice on that config.
KellyW
March 5, 2018
Hi Shirish,
Just a thought... did you add the following to the Tomcat connector:
scheme="https" proxyName="xx.xxx.xxx" proxyPort="443"
What's the error your are getting upon accessing the HTTPS link?
Kelly
Dear @KellyW
Thanks for your reply
Please find the below screenshot
When I access HTTPS
I am getting
This site can’t be reached
Please advise me
Many Thanks
IT-Admin
KellyW
March 7, 2018
Hi Shirish,
JIRA application sits behind a reverse proxy may not know the URL scheme, hostname or port to connect to Tomcat.
Please ensure that the server can resolve the hostname 'ariadne.swiss'.
Kelly
March 7, 2018
Are your ProxyPass  and  ProxyPassReverse configured well to point to AJP Host and Port ?
March 7, 2018
These should be mentioned in your SSL Config file - corresponding to what is on your server.xml file.
