×This question is in reference to Atlassian Documentation: Creating Issues via direct HTML links
Is it possible to find a "create issue details" screen that goes back to the create screen after current submission?
If you log in and use "create issue", there's a box at the bottom to tick for "create another". So, yes.
I am looking for the "create another option" to display When using the direct html links
Oh, I see, you won't get that if you use the links because the links land you on a full page rather than the pop-up which has the "create another" link.
