I have several fields larger than the popup window for the create issue. How can adapt it?
Thanks in advance.
Finally I modified the file
/includes/jira/dialog/Dialog-min.js
I set a bigger value than 810pixels
You'll need to amend the code generating the window to give it larger size parameters. It's in the core code of Jira.
Thanks, but can you help me on which file I must modify?
