"Critical" priority's description not updated
Summer X
I changed the description of "Critical" priority. It shows up correctly in Admin->View Priorities. But when I create/edit an issue and click on the little question mark, the description shown for "critical" priority is always "Crashes, loss of data, severe memory leak."
Other priorites do not have this problem.
Arthur Gonçalves
September 11, 2012
Hello SumTime,
This is currently a bug in JIRA, being tracked at the following link:https://jira.atlassian.com/browse/JRA-28051
To show the customized description, please change the priority name to don't match the default ones.
I hope this information helps! :)
Ken Ross January 29, 2013
If you intentionally misspell the word Critical using a capital I where the L should be it will appear correctly to the naked eye.
Summer X
Im running 5.1.2
Pedro Cora
September 11, 2012
What version of JIRA are you running?
