We use both Tempo and the issue Log Work screens to enter time spent on issues. While the Tempo screen for Log Work offers the current date, the issue Log Work screen starting offering the previous day (ex. July 5th, when the actual date is July 6th).
I've already checked the server date, and since it's in our physical office it is already configured to the correct (current) date. This is the value which shows in System Info. Any idea on what might have caused this change?
Hi all, Tempo released an update yesterday that fixes the problem. Upgrade to 8.0.1.3!
I heard back from Tempo yesterday, sorry for the delay in updating you all. It's a known issue and they're working on a fix. Hopefully it's out very soon.
I usually disable the original JIRA Log Work action
https://confluence.atlassian.com/jirakb/how-to-disable-the-log-work-option-in-jira-715129243.html
Doesn't solve the problem, though- neither logging time from the ticket, nor from the Tempo Timesheet, gives the correct date.
Looks like this was introduced with an update. Will report to Tempo
And the server time seems to be correct, so I think the problem must be within Tempo.
We are seeing this as well. Tempo knows the correct date, but the tracker and the log work window select yesterday instead of today.
