"ORDER BY Rank ASC" causing specific epic not to show up in filter results.
Robert Anthony
My users are new to JIRA Agile. They are not "Ranking" anything. This advanced JQL Query causes one specific epic not to show up in the search results. When I remove "ORDER BY Rank ASC" from the JQL Query the epic appears. Any idea what someone clicked (or didn't click) on this issue to cause it not to show up? Thanks.
Nic Brough -Adaptavist-
September 22, 2015
The order by clause doesn't change the result set, just the display.  How many issues do the two filters tell you they are returning?
Robert Anthony
Excellent point. The results are the same regardless. After taking a closer look at this the issue is actually with the board associated with the filter. Even under epics, when "All issues" is selected, the issue doesn't show up. Any idea?
September 22, 2015
Ok, that's handy debugging info - the issue navigator returns everything because they're all issues as far as it is concerned. A scrum board will generally show Epics on the epics tab, not in the backlog, because you don't plan or work on Epics directly.
Robert Anthony
Hi Nic, OK I have more information. So the issue is in the SCRUM board itself. Under the epics tab, all the epics for the project show up, except this specific epic. Any idea why that would happen?
September 22, 2015
Immediately, no. With a nap and a bit more coffee, well, not a lot more. Intriguing... Could you do a couple more things: 1. Check if the missing Epic has *any* links to any issues on that do appear on the board? 2. Compare the missing Epic with one that does appear. What are the differences? (Not to worried about text - if they've got different descriptions or titles, that's fine, but a difference such as "the one that appears has a description, but the other one does not" is important)
Robert Anthony
1. Epic had no missing links to outside issues that appear on the board. Some may have existed previously, but project admin deleted issues and created new epic that appeared perfectly. I added a new test ticket to this epic and verified it appears in "All issues" section of agile, but the epic itself does not appear in the epics column, so confusing! 2. I cannot see any difference between this epic and others created. I even clicked edit on both a working epic and this one, comparing edit screens to see if something was adjusted and not visible on view screens. Any thoughts?
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
