"Object doesn't support property or methog 'click'" error showing at top of window in IE
Jamie Gordon
Details
• Exception: Object doesn't support property or methog 'click'
• Resource: https://jira.atlassian.com/s/en_UKsx8qk0/710/2/1.0.8-beta/_/download/batch/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector.js
• Line: 24
Environment
Mozulla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; WOW64; Trident/5.0; SLCC2; .NET CLR 2.0.30729; Media Center PC 6.0; InfoPath. 3)
Faisal
August 7, 2012
Hey Jamie,
May I know which screen did the error occured? Anyway, looking at the resource URL:
- https://jira.atlassian.com/s/en_UKsx8qk0/710/2/1.0.8-beta/_/download/batch/com.atlassian.jira.collector.plugin....
It looks like this could be related to the Issue Collector plugin. If this problem arise when you access GreenHopper, then can you kindly try to disable the collector module in GreenHopper plugin and see if it helps?
You may access for GreenHopper plugin modules by going to:
- Administration > Plugins > Manage Existings > GreenHopper
Hope that the info helps.
Cheers!
Faisal
August 7, 2012
As a supplement to the above comment, perhaps the following KB article may help:
- https://confluence.atlassian.com/display/GHKB/Removing+Feedback+Related+Errors
Deleted user August 7, 2012
  1. Go to Administration > Plugins > Plugins
  2. When the plugins page appears, click on the Manage Existing (Tab), and locate & click the GreenHopper
  3. Once you have clicked on the GreenHopper plugin, you will see a link called Manage Plugin Modules. Click on that link to extends its modules
  4. When the list of modules appears, locate the module "Feedback" and you a button Disable will appear on the right side.
  5. Disable the feedback module and see whether the problem persists
This was from another similar question and worked for me.
Register now
