I'm getting below information while i try to update the existing issues in Jira with new values.
"while updating issues have been skipped because they already exist in destination projects."
Please let me know why i get this error. I'm Jira administrator. Below are the steps i follow:
In Jira settings --> System --> Import and Export --> External System Import -->
1. I get Jira Import wizard
2. I selected CSV
3. I got new page as CSV file import. Here i have File import and i uploaded the CSV file which i prepared. (Note issue key and all details are available. My aim is to change the Story points in each issues to a new value in Jira using this bulk option)
4. I map in the next page "Fields" only the Issue key and Story points.
Output is what is mentioned in the first line.
Request to guide me in steps (micro level) so that it can benefit everyone.
Thanks in advance
Hello Satheesh,
The steps below should work for you:
- Export the existing issues that you would like to update from JIRA to a CSV file (Export all fields)
- Use a spreadsheet software to edit the Story points in the CSV file
- Import it back, mapping the issue key, summary, Story points and project information (Key, Description, etc)
If the steps above do not work, can you please describe to us if you have changed any other fields in the CSV apart from the Story Points?
Also, provide us with the field columns that you are importing on your CSV.
Additionally, Story points are restricted to only a few issue types by default. That been said, I would recommend you to check if the issue type you are configuring is properly added in the context of Story points custom field. Here are the steps:
- Navigate to JIRA Settings > Issues > Custom fields
- Find the Story Points field > Click Configure
- Check for what issue types the field is applicable
For more details about CSV import, check the documentation below:
We will be waiting for your answer.
I was able to update subtasks once by following the steps above.
When I made further edits and imported the same CSV file again, I got the "issues have been skipped because they already exist" message.
The only way I could find to update the issues again was to include both the parent issue and the subtasks in the CSV, and change their "Issue id" and "Parent id" fields, respectively, to a new value for every import.
Hello Hannes,
That's awkward. Could you please double check if the issues were not edited with the new fields you updated in the CSV file?
It's expected that the issues will be skipped from being created since you are mapping the same issue key, however, the changes must be implemented to the existing issues.
Please, provide me the following information so I can try to reproduce the problem:
- You are importing tasks and sub-tasks only?
- Are you using JIRA Cloud or JIRA Server?
- What is the project type that you are trying to import the issues?
- What fields you are updating when importing the issues exactly?
I am getting the exact same problem. Issues skipped no matter what I do :(
I have the same issue. What worked in our dev environment was deleting all the issues in the project. Not a practical workaround in a production environment.
I did it.
What you're looking for is the External Issue Id field which is valued at each import.
So, in the "Issue layout" you need to add it and clean it.
Then you'll be able to Import as many times as you want, just remember to clean this field.
Cheers
hi @Celine Penaredondo , you need to edit your "issue layout" and show it :)
if you need more help let me know!
Hi @Daniele Donnini . Thank you for replying.
Are you referring to this? I got a 1 project and 0 issues importer successfully.
But when I checked the resolved date, it was still blank. I am trying to update the Date of resolution of these issues btw.
What do you mean clean it? Do you mean leave it blank on the CSV?
Na, @Celine Penaredondo. Bad explaination!
Go to "Filters" -> "Advanced issue search".
To the left, "Columns" and search for "External Issue Id".
Top right corner, three dots icon, "Bulk change all XXX issues"
Erase that damned field :D
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
