rank and priority sorting
Jira Median
The backlog is ordered by default by rank and we have the rank functionnality to have the drag n drop functionnality.
But is it possible to sort by rank ASC and by priority DESC and have the drag n drop functionnality ?
because when we add the priority sorting we don't have anymore the drag n drop.
thanks
4 votes
Ignacio Pulgar
December 8, 2017
Ordering by Rank ASC is a requirement for the drag&drop to work; no workarounds for that.
The best you can do is reordering them manually, possibly by taking advantage of multiple selection capability > mouse right click > send to top/bottom.
Matthew Jevne
October 16, 2018
Technically not solved.  No solution isn't a solution :)
Like # people like this
Nic Brough -Adaptavist-
October 16, 2018
There's a reason the flag is called "accepted".
Also, there is no "solution" - if you want to rank a list, you have to use a rank.
lukas.bohrmann
October 30, 2018
I understand that there is no solution for ranking and also ordering by priority inside of one sprint. But if I prefer to order my sprints by priority, why am I not allowed to use the right-click and move from one sprint to another. I see no contradiction.
Caleb Collins-Parks
May 14, 2019
I would love to see automatic rank/priority ordering implemented as a feature.
heather johnpillai
Given I'm a user vs. an admin, I would like to have a mechanism in JQL to be able to determine the order of values within a field.  Let me know if there is a way that I've not found.
Jj Cv
January 12, 2020
It doesn't sound intuitive...if i filter by name and description I would expect a sorted list by name and in case of same name a second sort by description...
I think similar pattern should apply when sorting by rank ASC and by priority DESC,
First sort by rank and when the rank is the same sort by priority...therefore the first time i apply the rank filter all elements should have same rank(since i have not drag&drop any element yet) and a second sort should apply based on the next order by criteria...no?
Al Capone
February 18, 2020
I think there could be added feature to rank items around the same priority level only. For example lets have 3 items of high priority - currently Jira decides about the order while I sort with priority. Would be great if I could change the rank of the 3 items because I want the last one on the list to be done first.
To summarize I would have items ordered automatically by different priorities and ranked inside of each priority lvl. Of course ranking items between different priorities could be restricted.
Ben Hill
May 10, 2024
@Al Capone I agree with you! I wish we could do:
ORDER BY priority DECS, rank ASC
so that cards with the same priority could be manually moved around.
3 votes
Markus_COGNITIFF
I interpret the meaning of “rank” more broadly. The decision to assign an issue specific rank is typically based on some underlying business rule. For example, issue X ranks higher than Y because it has more customer value (or takes less time to implement). The execution of that decision in the default Jira implementation is manual – users arrange issues in the desired order using drag-and-drop, and the resulting ranking is stored in the rank system field.
I think the inconvenience that people mentioned arises in situations where the data that feeds into the ranking decision already exists in Jira, like Priority or Story Points. So, for example, ranking all issues in a backlog by Story Points in descending order requires moving issues up and down by hand, even if each has a story point value. Understandably, it can get frustrating.
One way to accomplish the above sort order is to add Priority (or Story Points) to the ‘order by’ clause of the board query. But as Nic says, since issues are no longer sorted by rank but by Priority directly, drag and drop stops working. It is logical if you think about it – drag-and-drop cannot change the priority or the story points of an issue.
Another way is to use a plugin that works with the rank field. The plugin will update the rank based on a rule that you define. You can have a look at Sort by any Field plugin our company (COGNITIFF) developed for this purpose, since we were facing the same issue.
Ignacio Pulgar
June 16, 2020
Cool solution! Upvoted!
By the way, it would also be great if it supported a given calculation, like Value / Story Points, or something like that.
Promising app. Will test it soon!
Regards
ChalkyNZ May 18, 2022
Yeah I’ve found myself wanting both, but if you had both, and a new issue is created, how would it be sorted?
Also if you’re only ranking within same priority, can have a board with swimlanes priority but ordered by rank.
John Worrall
I teach my product owners to use rank to determine the order in which they want things worked on, which is not always the same as priority.
Something may be a high priority ask, but may not be urgent.  Something could be a low priority, but easy to deal with, and the person who knows how to do it best may be going on vacation next week, etc etc, and you put it at the top of the list so that they see it, even if the work itself is not a burning hot priority.
Priority in Jira is a terrific way to quickly see how important a ticket is, and if you want to, you can run queries to see how well your team handles A-level, B-level, etc... but in terms of actually managing your workflow, Rank determines where people will see the ticket in a list, and to me, that's what matters more (unless for some reason I'm filtering a list by priority, which I try to avoid doing, because it ignores rank).
I hope this makes sense to folks.
Oleg Andreyev
December 18, 2024
Idk migrated from GitHub Board where they have sorting by two fields and drag-n-drop so it’s totally possible, but for some reason Jira Devs are refusing it.
Mikaela Bertucci
Ok so I just made a work around.
I created false sprints for each of my rankings.
Must Have,
Should Have
Could Have
Won't have
Then I ran a filter with order by priority asc .. which then sorted my backlog quickly. Then selected all of the Must Have's right clicked and added them to the false sprint Must Have.
And then I did the same for Should Have, Could Have and Won't Have.
Then changed the backlog filter back to order by rank asc
So now the false sprints act like group by
Mikaela Bertucci
Shouldn't this be a simple query.. group by priority and then order by rank????????????????
JQL doesn't allow group by.. how come??????????
June 1, 2020
That can't work because you couldn't then rank the issues.
There's no "group by" because JQL is a search for issues, it has nothing to say about what you report the list on.
Elisabeta Kozak October 25, 2023
This should be simpler than that:
ORDER BY priority DESC, Rank ASC
would allow ordering by priority and within the same priority to drag and drop (and update the rank)
October 29, 2023
I'm afraid that won't work - for ranking to work, you need to be able to rank across priorities.  Ranking and prioritisation are not the same thing.
Elisabeta Kozak October 30, 2023
For when you need to Rank across priorities, you have the current setting
ORDER BY Rank ASC
What I was proposing was for ranking within a priority :)
October 30, 2023
But it won't work, because ranking and prioritisation are not the same thing.
Elisabeta Kozak May 20, 2024
It would, the result for ORDER BY priority DESC, Rank ASC would look like:
  • Priority 1 - Rank 1
  • Priority 1 - Rank 2
  • Priority 1 - Rank 3
  • Priority 2 - Rank 1
  • Priority 2 - Rank 2
  • Priority 2 - Rank 3
  • Priority 3 - Rank 1
  • Priority 3 - Rank 2
  • Priority 3 - Rank 3
Maybe this clarifies a bit what we are aiming for :)
May 23, 2024
That cannot work - to rank an issue, by definition, it has to be a unique placement in the list.
And, again, ranking and prioritisation are not the same thing.
Deleted user September 24, 2018
Not really user friendly as the whole concept of the backlog is implementation according to priority. Is the status still the same?
September 24, 2018
Yes, it has not changed, and it won't change either.  The concept of a backlog implementation is that you put your issues in order, which you can't do with priority, you have to do it with a rank.
Thanks, can you help a bit on to use ranking? Is it just the manual order that you put your self in the dashboard backlog, when I add the field it look more like a code than a usable thing for user.
September 24, 2018
Yes, it's the order you put things in on the backlog.  The field it is in is not really human readable, don't bother putting it on screens.
Like DeNae Leverentz likes this
Thank you so much
