read data from Excel and convert to JSON using groovy script in scriptrunner
sgole
February 19, 2020 edited
i have readied  data from excel and store in List<List<String>> . the data is below .now i want to convert below data in json format ..how can i do that
sgole
thanks . i have solved myself by referring below link,'
https://www.dev2qa.com/convert-excel-to-json-in-java-example/
Mehhss January 7, 2024
May I ask how did you read the excel data from Scriptrunner using groovy script?
Nic Brough (Adaptavist)
I am slightly unsure of what you are trying to do here.
Your first line of code is reading a .csv file and you want the output in JSON format, I understand that, but what does this have to do with a REST endpoint?
Perhaps if you could explain what you're trying to do overall, rather than think of a specific solution or function you think may help, we can better guide you?
sgole
@Nic Brough (Adaptavist)  i have modified question please check
Register here ⬇️
