removing customfield in configure coulumns in 6.3
s@ii April 6, 2015
how to restrict the customfield options auto displaying in search box in 6.3 via script..?
Nic Brough -Adaptavist-
April 6, 2015
There's not enough information here.  Answers is not on version 6.3 and doesn't have configure columns - do you really mean JIRA?
And what do you mean by "script"?  And why?  If you are talking about JIRA, and you're trying to stop offering fields to users, then you have a nightmare of a job becasue your script is going to have to understand your entire user-to-project-to-field relationships to know which ones it should hide
s@ii April 7, 2015
we have already  implemented this in JIRA 5.2 (i.e to restrict a custom field in configure colums of the issue navigator.) we have done this by taking the id of the drop down list of the configure column list via jquery.
where as in JIRA 6.3 the list is being displaying in a different way (by the help of search box).
how can i restrict via jquery..?(which id i have to use)
April 7, 2015
Yes, one of the many reasons for NOT trying to be clever with javascript - it usually breaks on every upgrade. I'm not sure you can do this as simply as you could in Jira 5.2 - I'd strongly suggest starting again from scratch. Although I really don't see any use for wanting to remove the columns either - my instinct would be not to even bother.
