×So, I have a list of 25 epics. Out of these, I am trying to list all issue types (task, story, subtask) if the epic's TargetEndDate is between two dates say Feb 1 to April 30.
I have tried:
"Target End Date" >= 2023-11-01 AND "Target End Date" <= 2024-01-31 AND parent in (A-1234, A-5678, A-9129) ORDER BY status ASC
"Target End Date" >= 2023-11-01 AND "Target End Date" <= 2024-05-31 AND issueFunction in epicsOf("parent in (A-1234, A-5678, A-9129)") ORDER BY status ASC
Hello @Shachi Prasad and welcome to the Community! If you use ScriptRunner, the following should work:
issueFunction in issuesInEpics("'Target End Date' >= 2023-11-01 AND 'Target End Date' <= 2024-01-31")
this will search all the epics. I want the query to search only from the given list of epics
If I add the list of epics, it doesnt return anything.
issueFunction in issuesInEpics("'Epic Link' in (A-1234, A-5678, A-9129) AND 'Target End Date' >= 2023-11-01 AND 'Target End Date' <= 2024-01-31")
@Shachi Prasad Are you in Cloud or data center?
If in DC:
If in Cloud:
issueFunction in issuesInEpics("'Parent' in (A-1234, A-5678, A-9129) AND 'Target End Date' >= 2023-11-01 AND 'Target End Date' <= 2024-01-31")
If still issues, try to first find the epics. Does any of below query give you data?
OR
Cause if above query is not give you Epics, obviously issuefunction will not return any stories.
This returns data:
but when I surround it with issueFunction, it doesnt.
Also, I am trying to get all the tasks and stories under an epic if the target end date is given within the desired date range but tasks and stories under that epic may or may not have the value for target end date.
Apologies. If A-1234 etc are Epics, your query should be:
'key' in (A-1234, A-5678, A-9129) AND 'Target End Date' >= 2023-11-01 AND 'Target End Date' <= 2024-01-31
AND
issueFunction in issuesInEpics("'key' in (A-1234, A-5678, A-9129) AND 'Target End Date' >= 2023-11-01 AND 'Target End Date' <= 2024-01-31")
I dont know what I was thinking before.
Above query should get you stories/tasks belonging to epics A-1234 etc which have target date in the range you have mentioned.
