Hi
how can i save my custom data to jira hsql db? does jira automatically backup my custom data like other data in db (such as issues) in the xml files?
thanks
First, there's no point in coding for HSQL - you would never use your code on a production system because you would never use HSQL in production.
Second, forget the database, you should not use it directly. Use the internals of Jira to handle the database and you can stop worrying about backup and all the other stuff that goes into the database. You can also forget about what type of database it is
Finally, for storing your own data in Atlassian application databases, use Active Objects. Start at https://developer.atlassian.com/display/DOCS/Active+Objects
thanks Nic
my jira version is 3.7 so i guess i can not use active objects,is it right?
i find 2 approach to store mydata to database
1-using SAL
2-using ofbiz
for SAL again ,it seams that it is not supported by my jira version
if ofbiz is the solution, how can i use it to store my data ?
is there any other way for my purpose?
I think you're right, for Jira 3.7, you'll need to use ofbiz.
I'm afraid I don't know where to start with that. Personally, I'd upgrade as you're out of support and active objects make it soo much easier, the first time I needed to store anything outside the config of a plugin, I upgraded instead of try to learn ofbiz.
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!Online forums and learning are now in one easy-to-use experience.
