I have a custom field called "location" that is a dropdown with the value options being Building A, Building B, and Building C. When a customer is creating an issue and they choose their location, I would like it to automatically update another custom field called "Team" with the corresponding team assigned to that location.
For example, when a customer chooses "Building A" when they create their issue, I would like it to automatically populate the team field with "Team A." Same for Building B-Team B and Building C-Team C.
Is this achievable with ScriptRunner?
Thank you for the help. I have actually solved the issue with the Workflow plugin with the following rules (below) for 'Set a field as a function of other fields Function.' and setting the Location field as the Field to be Checked and the Team field as the Target Field. Seemed to be the simplest and quickest way to accomplish.
(Building A)Team A
(Building B)Team B
(Building C)Team C
You can do this with Custom Listener that triggers on Issue Created event. This requires a script in Groovy though.
If you want to take a stab at it and already have ScriptRunner installed go to: https://yourjirainstance.com/plugins/servlet/scriptrunner/builtin?section=script_listeners (of course change "yourjirainstance.com" with address to your Jira) and create Custom Listener with following Inline Script:
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.ModifiedValue import com.atlassian.jira.issue.util.DefaultIssueChangeHolder def currentIssue = event.issue; def customFieldManager = ComponentAccessor.getCustomFieldManager(); def locationField = customFieldManager.getCustomFieldObjectByName("Location"); def teamField = customFieldManager.getCustomFieldObjectByName("Team") def locationFieldValue = currentIssue.getCustomFieldValue(locationField); def locationFieldValueString = locationFieldValue.toString() def optionsManager = ComponentAccessor.getOptionsManager(); def changeHolder = new DefaultIssueChangeHolder(); if (locationFieldValueString == "Building A") { def teamFieldOption = optionsManager.getOptions(teamField.getRelevantConfig(currentIssue)).find {it.value == "Team A"}; teamField.updateValue(null, currentIssue, new ModifiedValue(currentIssue.getCustomFieldValue(teamField), teamFieldOption), changeHolder); } else if (locationFieldValueString == "Building B") { def teamFieldOption = optionsManager.getOptions(teamField.getRelevantConfig(currentIssue)).find {it.value == "Team B"}; teamField.updateValue(null, currentIssue, new ModifiedValue(currentIssue.getCustomFieldValue(teamField), teamFieldOption), changeHolder); } else if (locationFieldValueString == "Building C") { def teamFieldOption = optionsManager.getOptions(teamField.getRelevantConfig(currentIssue)).find {it.value == "Team C"}; teamField.updateValue(null, currentIssue, new ModifiedValue(currentIssue.getCustomFieldValue(teamField), teamFieldOption), changeHolder); }
Note that only recent versions of ScriptRunner have inline scripting functionality (otherwise you have to save script to file and provide path to the script accessible on the server).
I didn't test the code but this is the general gist.
Best of luck and let us know if you have solved your problem (and how)!
Does it make a difference if the Team custom field is a group picker? The code runs with no errors, but it doesn't actually assign the Team value. Is this because it has the field type of "group picker"?
I don't have experience with "group picker" but this works for "user picker" so I assume code will be somewhat similar:
import com.atlassian.jira.issue.ModifiedValue import com.atlassian.jira.issue.util.DefaultIssueChangeHolder import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.customfields.manager.OptionsManager def currentIssue = event.issue; def customFieldManager = ComponentAccessor.getCustomFieldManager(); def optionsManager = ComponentAccessor.getOptionsManager(); def changeHolder = new DefaultIssueChangeHolder(); def userManager = ComponentAccessor.getUserManager() def user = userManager.getUserByName("username"); def userField = customFieldManager.getCustomFieldObjects(currentIssue).find {it.name == 'User Picker'}; userField.updateValue(null, currentIssue, new ModifiedValue(currentIssue.getCustomFieldValue(userField), user), changeHolder);
Can anyone provide me a sample syntax for this logic?
IF dropdown_field = option3 or option4 then Text_field =Required END IF
Hi @Ron Gates
I have similar issue Can you please help me with the Script my requirement is
I have Group Field called "Assignment Group"
Group X : A,B,C,D
Group Y : E,F,G,H
Group Z : I,J,K,L
So in a project if any user is Creating Issue or Issue Updating if that issue is assignee to " A " user the group filed has to automatically update to Group "X".
same like that depends up on assignee user the group filed has to change to user related group
I have modified the above script and I performed on Custom Listener
def assigneeField = customFieldManager.getCustomFieldObjectByName("assignee");
def assignmentgroupField = customFieldManager.getCustomFieldObjectByName("Assignment Group")
def assigneeFieldValue = currentIssue.getCustomFieldValue(assigneeField);
def assigneeFieldValueString = assigneeFieldValue.toString()
if (assigneeFieldValueString == "kumar") {
def assignmentgroupFieldOption = optionsManager.getOptions(assignmentgroupField.getRelevantConfig(currentIssue)).find {it.value == "Incident-Developer1"};
assignmentgroupField.updateValue(null, currentIssue, new ModifiedValue(currentIssue.getCustomFieldValue(assignmentgroupField), assignmentgroupFieldOption), changeHolder);
here is the Logs :
2019-01-16 16:40:58,911 ERROR [runner.AbstractScriptListener]: ************************************************************************************* 2019-01-16 16:40:58,912 ERROR [runner.AbstractScriptListener]: Script function failed on event: com.atlassian.jira.event.issue.IssueEvent, file: <inline script> java.lang.NullPointerException at com.atlassian.jira.issue.IssueImpl.getCustomFieldValue(IssueImpl.java:896) at com.atlassian.jira.issue.Issue$getCustomFieldValue$5.call(Unknown Source) at Script930.run(Script930.groovy:9)
the script does not have any errors but when i assign the Issue to my id the group field not generating the value
Can you please help me here
Kumar
This throws "Static type checking error" for events as undeclared in Scriptrunner console.
Any alternate method there ! to capture the event and update the fields via Scriptrunner Console.
Save your spot
