the query that cause de block in db
(@P0 nvarchar(4000),@P1 nvarchar(4000),@P2 nvarchar(4000))
insert into "dbo"."AO_F1B27B_PROMISE_HISTORY" ("KEY_HASH", "TASK_KEY", "CLASSIFICATION") values ( @P0 , @P1 , @P2 )
here my script, what im doing wrong?
import com.atlassian.jira.ManagerFactory
import com.atlassian.jira.project.Project
import com.atlassian.jira.issue.link.IssueLinkTypeManager
import com.atlassian.jira.issue.index.IssueIndexingService
import com.atlassian.jira.issue.IssueInputParameters
import com.atlassian.jira.bc.issue.IssueService
import com.atlassian.jira.util.ImportUtils
import org.apache.log4j.Category
def Category log = Category.getInstance("com.onresolve.jira.groovy.PostFunction")
log.setLevel(org.apache.log4j.Level.DEBUG)
log.debug ("iniciando clone ")
log.debug ("declarando variables")
def issueManager = ComponentAccessor.issueManager
def issueFactory = ComponentAccessor.getIssueFactory()
def authenticationContext = ComponentAccessor.getJiraAuthenticationContext()
def issueLinkManager = ComponentAccessor.getIssueLinkManager()
def customFieldManager =ComponentAccessor.getCustomFieldManager()
def userUtil = ComponentAccessor.getUserUtil()
def projectMgr = ComponentAccessor.getProjectManager()
def issueLinkTypeManager = ComponentAccessor.getComponentOfType(IssueLinkTypeManager.class)
def issueLinkType = issueLinkTypeManager.getIssueLinkTypesByName('Problem/Incident')[0];
def issueIndexingService = ComponentAccessor.getComponent(IssueIndexingService)
def issueService = ComponentAccessor.getIssueService();
def IssueInputParameters issueInputParameters = issueService.newIssueInputParameters();
log.debug ("Inicializando inputparameters")
issueInputParameters.setProjectId(projectMgr.getProjectObjByKey("CREOSD2").Id); //JSD project
issueInputParameters.setIssueTypeId(issue.issueType.id);
issueInputParameters.setSummary(issue.summary);
issueInputParameters.setReporterId(issue.getReporterId());
issueInputParameters.setDescription(issue.description);
log.debug ("IssueService.ValidateCreate")
IssueService.CreateValidationResult validationResult = issueService.validateCreate(authenticationContext.getLoggedInUser(), issueInputParameters); //issueObject.getReporter()
if(!validationResult.isValid())
log.debug("Could not create issue: " + validationResult.getErrorCollection());
else
// Create new issue
log.debug ("Trying crear issue")
IssueService.IssueResult createResult = issueService.create(authenticationContext.getLoggedInUser(), validationResult);
log.error("Issue Created")
if (!createResult.isValid())
log.error("Issue was not created!")
} else {
log.error("Issue was created. Issue Id: " + createResult.getIssue().getKey())
Hi Jamie,
here the screen of block in database
here the detail of SPID 62, the query that causes the "block"
Also JIRA screen stucks, and the only way to resolve the problem, is restarting JIRA Service or kill the process (in database)
im using sql server 2008
NOTE: This problem is only with JIRA Service Desk Project with SLA configured
if i delete all SLA definition, all works!
What exactly do you mean by "block in db"?
What is different when you run it in Script Console, is it the issue that you are copying?
What DMBS are you using?
Hi Jamie,
I detected this issue happens only if the target is a JIRA Service Desk Project with SLA configured.
if i copy/paste the script in Add-ons->SCript Ruhnner->Script Console and change the values of issueInpurtParameteres (hardcode) it works!
i dont understand why in a postfunction inside a workflow it doesnt work
thanks,
i used: projectMgr.getProjectObjByKey("CREOSD2").getId()
the error persists
is wrong, should be
projectMgr.getProjectObjByKey("CREOSD2").id
You may have other problems but you should at least start with something that will compile.
