Hello
I am trying to create script runner validator that should check select list custom field and another field based on select list field.
E.g. I have select list FieldA with values "Yes", "No" and "None" (empty). I need to check if FieldA is "Yes", then "FieldB" should be > 0. So my current working validator is
(cfValues['FieldA'].getValue() == "Yes" && cfValues['FieldB'] > 0) || (cfValues['FieldA'].getValue() == 'No')
But I need also to check if fieldA is "None", and I am unable to find correct statement for it I tried
(cfValues['FieldA'].getValue() == "Yes" && cfValues['FieldB'] > 0) || (cfValues['FieldA'].getValue() == 'No') || (cfValues['FieldA'] == null)
but it seems it is doesn;t work
What is the correct statement? Is it possible to optimize validator expression (without writing expression in one row) e.g.:
if(fieldA=="Yes"){ if(fieldB<=0){ //Validator was NOT passed // show message } else{ //validator was passed } } else{ //validator was passed }
Thank you in advance,
Fyodor
It's better to use Groovy Truth than comparisons with null. So to check if it has a value:
if (cfValues['FieldA']) ...
to check if it doesn't have a value:
if (! cfValues['FieldA']) ...
You don't need to write it in one line, if you hit enter the text box will expand. Seems to be a common misconception that it must be a one-liner... bad UI design probably.
If it's clearer to write it in 10 lines with "if"s and "return"s then definitely do that.
@JamieA I have a Q too:
I would like to reject the option for setting the "Fixed in version/s" filed as long as the "Affects Version/s" field is empty
how should I write it with script validator?
Hi Shelly
If you trying to update field's value based on another field, I think it will be better to use post-function or listener, not validator
If you need validator that checks issue's fields you can use something like:
result=true
if (cfValues['CustomFieldA']){
if (cfValues['CustomFieldB'].getValue() == "Yes") {
if(cfValues['CustomFieldA'] <= 0){
result=false;
return result;
This °validator checks "CustomFieldA" (number custom field) value when 'CustomFieldB' (select custom field) has YES value.
Thanks Fyodor,
What I need is that:
if field A is empty/null than field B will be grey out - meaning, there will be no option to add value to this field. or make field B disappear
Hmm....
I think it could be configured by behavior (Manage Addons -> behaviors....), but I haven't tried this functional yet....
Other possible soltuion - create postfunction or listener that updates one field value based on another field value.
Something like this listener example:
MutableIssue issueToUpdate = (MutableIssue) event.issue;
def acceptedIssueTypes = ["typeA", "typeB"];
if(issueToUpdate.getIssueType().name in (acceptedIssueTypes)){
//some value
def someval = 100;
//find specific custom field
def CF = customFieldManager.getCustomFieldObjectByName('CF');
//set CF field and fire update issue event
issueToUpdate.setCustomFieldValue(CF, someval);
issueManager.updateIssue(event.getUser(), issueToUpdate, EventDispatchOption.ISSUE_UPDATED, false);
Hello Jamie
Thank you for assistance, it works.
Fyodor
Hello Jamie and Simon.
Thank you for fast reply.
Could you describe me how can I put multi-row code? Expression should return TRUE (see screenshot), so I don't understand how can I put code with if, else etc ?
Could you show me an example?
Plugin version is 2.1.17
Best regards,
Fyodor
Like:
if (1) { return true } else { return false }
am I missing someting?
The return keyword is actually optional for the last statement executed, but you can put it in for clarity.
Hey there,
"!= null" instead off ">0" could work and
you could check if you imported all nessesary data.
Like "import com.atlassian.jira.issue.Issue;"
That was often my problem ..
Hope this can help.
Greets
Simon
Register now
