scripted default value on issue creation screen
Ireen Klein_Actonic
We use a custom field "Student". When an issue is created a default value should be set. It should be the current user.
I have no programming skills, but we use scriptrunner. Somebody an idea?
Thank you very much for your advice!
Alexey Matveev
July 29, 2018
It would be something like this:
def user = ComponentAccessor.getJiraAuthenticationContext.getLoggedInUser()
def studentCF = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Student")
issue.setCustomFieldValue(studentCF, user)
ComponentAccessor.getIssueManager().updateIssue(user, issue, EventDispatchOption.ISSUE_UPDATED, false)
Put this script into a scripted post function and put this post function last in the list of post functions.
Ireen Klein_Actonic
It should already be visible when the create issue screen is seen.
Alexey Matveev
August 2, 2018
Then it should be a behaviour with a script like this:
if (getActionName().equals("Create") {
def studentCF = getFieldByName("Student")
studentCF.setFormValue(user);
Ireen Klein_Actonic
I solved this issue now by using Live Fields with the following script:
string currentUser=currentUser();
if(argv["screen"]=="create") {
lfSet("Student",currentUser);
Help us plant more trees
