Does anybody know how to read csv file and insert data to mssql table using scriptrunner script in job
I've a csv file test.csv with structure like below:
"first_column","second_column"
"first_column_value","second_column_value"
I need to read this file and insert data to mssql table called DEST by scriptrunner script
For your requirement, I suggest using the ScriptRunner console.
Below is a sample working code for your reference:-
import groovy.sql.Sql
import java.sql.Driver
def props = new Properties()
props.setProperty('user', 'root')
props.setProperty('password', 'qwerty')
def driver = Class.forName('com.mysql.jdbc.Driver').newInstance() as Driver
def conn = driver.connect('jdbc:mysql://localhost:3306/MOCK', props)
def sql = new Sql(conn)
* Path to the CSV file
def file = new File('/home/ram/Downloads/content.csv')
def list = [] as ArrayList<Map>
def insertions = [] as List<String>
* Extract the value from the CSV file and add it to a List of Maps
file.eachLine {
def column = it.split(',')
def mapInput = [:] as Map
mapInput.put('First_Column', column[0])
mapInput.put('Second_Column', column[1])
list.add(mapInput)
try {
list.each {
sql.execute("""
INSERT INTO example
(First_Column, Second_Column)
values (${it.values().first()}, ${it.values().last()})
} finally {
sql.close()
conn.close()
Please note that the sample code above is not 100% exact to your environment. Hence, you will need to make the required modifications.
Below is a screenshot of the configuration for your reference:-
Below is a copy of the sample csv file I have tested with:-
Sample 1 | Input 1 |
Sample 2 | Input 2 |
And below is the output in the database:-
I hope this helps to solve your question. :-)
Thank you and Kind regards,
Ram
Thanks for detailed solution.
It is works perfectly
