scriptrunner copy custom fields wrong filter result
Retmer van Dongen
I try to transfer the value of a custom field "Story points_deprecated" to the custom field "Story points". I only want to transfer the value for tickets which not already have a value in the "Story Points" field. I use scriptrunner build in script Copy custom field values. It processes all issues provided by a JQL-filter. I made the filter project = tdh AND "Story points_deprecated" != EMPTY AND "Story Points" = EMPTY and this results in 300 tickets in the issues viewer. However when I use it in scriptrunner the script ends immediately with the message 0 issues modified. The scriptrunner preview stated that 300 issues will be processed. There is nothing in log files.
Anybody a hint to resolve this?
Thanos Batagiannis [Adaptavist]
November 16, 2016
Hi Retmer,
Are you able to update to the latest version ? There was a bug that fixed in the latest version (SRJIRA-2095).
Alternatively add in your filter a clause that will exclude issues where the source custom field has null / no value.
Retmer van Dongen
Thanks, With version 4.3.13 it works correctly
November 17, 2016
nice smile
Vasiliy Zverev
November 16, 2016
Are you sure that custom field id were specified correctly?
