so i have this JQL
project = RMOB AND issuetype in (Bug, "Story Defect") AND resolution = Unresolved AND assignee in (membersOf(Others)) ORDER BY assignee ASC, updated DESC
I want to add both assignee in a group of Others, plus all the tickets that is unassigned. I tried to add AND assignee = Unassigned but it didnt work, i also added assignee != empty but it didnt work too :( ?
I suspect it's simply your JQL syntax
I'm not sure that I have understood the question, but if you mean that you're looking for a set of issues with "assignee is in a group called others, or unassigned", then
project = RMOB AND issuetype in (Bug, "Story Defect") AND resolution = Unresolved AND (assignee in (membersOf(Others)) OR assignee is empty)
should do it.
