select Approver from multi-user picker
Ragvi Ttpt
As part of our Workflow we have an approval process for which we are using a Multi-User picker. This transition will be considered approved if just one of the multiple approvers approves it. We currently have around 4 approvers in the multiple user picker.
Is there a way to know who is the one who "approved" it. I want to be able to mention the name of the person who approved it from the list of approvers. I am sending a confirmation email from my WorkFlow's Post function but having trouble figuring the field code for that.
So far I was able to grab the field code for the Multiple User Picker but unable to drill down into it !! In the Jira service desk portal, it displays a green check mark against the person who approved it in the list of all the approvers.
Would appreciate some help.
Moga
October 16, 2018
Hi Ragvi,
Looks like you will need to run a REST API to get the approver name - take a look at the REST API; servicedeskapi/request/{issueIdOrKey}/approval. From the result, you will be able to identify the approver.
Mogavenasan
