separate character in rtl language
meysam
March 9, 2017
hi
i have problem with rtl language .
in  "driven table admin" setting create one table  with below structure:
# Setup a grid to manage products
gd.columns = icode, iname, iprice
gd.tablename = products
gd.visiblerows=15
# Connect to the database to store the product list
gd.ds = jira
# Define the columns
col.icode = Code
col.icode.width = 100
col.icode.type = string
col.iname= Name
col.iname.width = 400
col.iname.type = string
col.iprice= Price
col.iprice.width = 100
col.iprice.type = number
CUSTOM FIELD SETTING
----------------------------------------Screenshot from 2017-03-09 15-51-28.png
col.sku=product name
col.sku.type = list
col.sku.query = select iname, icode, iprice from products_d1 order by iname
col.sku.query.ds = jira
col.sku.autocomplete = true
language of content for this table is persian (Right to left) and when trying select value from column "iname"  in list field (col.sku.type = list) all items is separate character in drop down list style but when select one item everything is ok and my value showed correctly.
how can i fix this?
King Regards
 meysam
meysam rahmani March 10, 2017
First thank a lot to iDalko Support team for help me.
Solution for other user is : (might have same problem)
remove "col.sku.autocomplete = true" line in custome fields setting.
Thanks Iev Strygul
meysam rahmani March 9, 2017
Hi Francis,
First thanks for your attention and I am really grateful to you.
francis
Hi Meysam,
You did raise this issue also in our support channel - thanks.
Is it ok to address it there, and then publish the outcome here ?
Francis
Register now
