I am fairly new to Script Runner Behavior and trying to write scripts with the help on examples available online – I must be missing something very obvious. :)
Based on the value Feature Request Category(FRC), mandatory/ optional settings of Model field must vary.
I have used script runner to dynamically mandate Model when FRC value is “Missing Special Test” and optional when FRC value is “Missing Vehicle Model”.
Model field is getting displayed as optional when Missing Vehicle Model is selected for the first time, but when the value of FRC is switched to Missing Special Test (where Model field is mandatory) and back to Missing Vehicle Model – Model field is not automatically switching to optional.
How to make it optional every time Missing Vehicle Model is selected?
Here are some screenshots -
How did you make it required? Did you write code?
Yes - please find my code below.
Should I be exclusively mentioning model.setRequired(false) in the if condition for Missing Vehicle Model?
def category = getFieldByName("Feature Request Category")
def year= getFieldByName("Year")
def make= getFieldByName("Make")
def model = getFieldByName("Model")
def crField = getFieldById(getFieldChanged())
def selectedOption = crField.getValue() as String
if ((selectedOption.contains("Missing Vehicle Model")))
year.setRequired(true)
make.setRequired(true)
else
model.setRequired(true)
Did you attach this code to the Feature Request Category? I mean, you added the Feature Request Category to your behaviour and added this code in this field?
Yes I did. Mapped to the Feature Request Category field and the project / Issue Type.
Added a line of code model.setRequired(false) to the if condition -first case and it seems to be working fine now. No matter in what order Feature Request Category values are selected the behavior of Model field seems to be working as expected. :)
Good to hear! :)
