setting a custom field (date) from due date
mathew wise September 11, 2019
hello,
On a single project i would like to set a custom field (date picker) from the Due Date on creation only.
how can i do this?
jira version = 7.12.3
scriptrunner = 5.5.6
thanks
Petter Gonçalves
September 12, 2019
Hello Mathew,
Thank you for reaching out.
I understood that you would like to add a new custom field to your screen that would receive the same value added to the Due date field, using Scriptrunner. Is it correct?
If that's what you are looking; for, Scriptrunner plugin has an inbuilt-script that you can use to do exactly what you want:
You can check the video below to know exactly how you can configure the script:
ScriptRunner - Copy custom field values
Let me know if this information helps.
Register today
