simple script validation
arild marthinussen October 24, 2013
Hi, I would like to add a simple script validator - to my Jira project
As a maintainer for the system IVH, when issues are tagged with system=IVH and status is open. When starting transition 'start progress' the custom fields 'IVH Architect' and 'IVH developer' must have a value. If not - an errormsg sholud promt "the fields IVH Arcitect' and 'IVH developer' must have a value before starting progress when system is IVH
Any idea's on how this could be done ?
Bharadwaj Jannu
October 24, 2013
you can write workflow validator plugin see the below
https://developer.atlassian.com/display/JIRADEV/Workflow+Plugin+Modules#WorkflowPluginModules-Validators
http://www.j-tricks.com/1/post/2010/08/workflow-validator.html
in that you can write a code like
CustomFieldManager cfm=ComponentAccessor.getCustomFieldManager();
InvalidInputException e= new InvalidInputException();
Set<Label> labels=issue.getLabels();{assuming issue tagging adding labels to it}
if(labels.size()==1)
String label=labels.getLabel();
if(label.equals("system=IVH") && issue.getStatusObject().getName().equals("Open"))
Object iVHArchitect=issue.getCustomFieldValue(cfm.getCustomFieldObjectByName("IVH Architect"));
Object iVHDeveloper=issue.getCustomFieldValue(cfm.getCustomFieldObjectByName("IVH developer"));
if(iVHArchitect ==null || iVHDeveloper==null)
 e.addError("the fields IVH Arcitect' and 'IVH developer' must have a value before starting progress when system is IVH");
 throw e;
Object system=issue.getCustomFieldValue(cfm.getCustomFieldObjectByName("system"));{assuming if system is a customfield}
if(system!=null && system.toString().equals("IVH"))
 throw e;
Bharadwaj Jannu
October 24, 2013
if you need built-in plugin go through Script Runner plugin.
Christian Czaia _Decadis AG_
October 24, 2013
You could check the following plugin. It has a "field has a value" condition built-in.
https://marketplace.atlassian.com/plugins/com.innovalog.jmwe.jira-misc-workflow-extensions
Other than that I'd go for Jamies behaviours or script runner plugin to script my way through...
https://marketplace.atlassian.com/plugins/com.onresolve.jira.plugin.Behaviours
https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner
Others can probably provide you with a script...
Cheers Christian
