simple scripted conditions on workflow transition - error on preview and always evaluate true
Sam Hasler February 10, 2017
I have a [Edit: workflow transition with a] simple scripted condition in which I have placed the single word "false", yet it behaves as if it evaluated to true.
When previewing it I see this error:
Cannot cast object 'haslers(haslers)' with class 'com.atlassian.jira.user.DelegatingApplicationUser' to class 'com.atlassian.crowd.embedded.api.User'
JIRA version: v7.1.4#71008-sha1:eaa0661
[EDIT]:
This is on server, not cloud, so I wonder if the com.atlassian.crowd.embedded.api.User is incorrectly referencing code in the cloud codebase (because of crowd) instead of the server codebase.
Here's a screenshot of how I've configured the script.
image2017-2-14 9:8:46.png
[EDIT2]
We're on version 3.0.10 and there's no budget for getting the paid version so I guess I'll have to look at an alternative way to do this that doesn't involve script runner. (would have replied in a comment but I don't have enough points)
Thanos Batagiannis [Adaptavist]
February 15, 2017
Hi Sam,
So yes the problem is that the 3.0.10 version is not compatible with the JIRA v7
Changes in the JIRA API, like the one you face, made it hard to make at least one free version compatible with JIRA v7.
regards, Thanos
Sam Hasler February 15, 2017
@Thanos Batagiannis [Adaptavist], I'm on version 3.0.10
Tarun Sapra
Indeed Thanos, I am aware that return is optional, but I wanted to make sure that a boolean is returned as a single false might have been interpreted as a string, as I not aware of the exact behind the scene semantics of the code that kicks in when the validation is executed.
http://stackoverflow.com/questions/8930325/groovy-truth-string-to-boolean-inconsistency
February 14, 2017
Tarun, in groovy, return is optional, so probably this is not the issue. I think the issue is with the ScriptRunner version  Sam uses.
Tarun Sapra
Did you try "return false;" instead of just false.
February 13, 2017
Hi Sam,
Which version of ScriptRunner you use ?
Sam Hasler February 13, 2017
I should have said, this is a condition on a workflow transition.
@Thanos Batagiannis [Adaptavist], My script is literally "false" (see attachment). So it should always fail, and yet it doesn't. This makes me think it's a bug in JIRA, unless I'm completely misunderstanding how simple scripted conditions work.
February 13, 2017
Learn more
