[solved] JIRA unresponsive
Miles December 18, 2017 edited
I came back from holidays to this:
2017-12-18 14:38:42,550 Caesium-1-3 INFO      [c.a.j.p.h.service.connect.InstallGlancesJobHandler] Running InstallGlancesJobHandler...
2017-12-18 14:38:42,551 Caesium-1-3 INFO      [c.a.j.p.h.service.connect.InstallGlancesJobHandler] There is no link to HipChat, no need to install glances.
2017-12-18 14:38:42,847 Caesium-1-4 INFO      [c.a.jira.i18n.I18nWarmer] Initialised i18n cache in 20255
2017-12-18 14:38:42,847 Caesium-1-4 INFO      [c.a.jira.startup.CacheWarmerLauncher] Warmed cache(s) in 20373 ms.
2017-12-18 14:39:14,282 Caesium-1-1 INFO      [c.a.jira.upgrade.UpgradeScheduler] Running scheduled upgrades
2017-12-18 14:39:14,320 Caesium-1-1 INFO      [c.a.jira.upgrade.LoggingUpgradeService] run upgrades has started
2017-12-18 14:39:14,565 Caesium-1-1 INFO      [c.a.j.upgrade.util.BuildNumberDao] Setting current build number to 76001
2017-12-18 14:39:14,575 Caesium-1-1 INFO      [c.a.jira.upgrade.UpgradeIndexManager] There is no reindex requests of type [IMMEDIATE, DELAYED] so none will be run
2017-12-18 14:39:14,576 Caesium-1-1 INFO      [c.a.j.upgrade.util.BuildNumberDao] Setting current version to 7.6.0
2017-12-18 14:39:14,580 Caesium-1-1 INFO      [c.a.j.upgrade.util.BuildNumberDao] Setting downgrade version to 7.1.2
2017-12-18 14:39:14,607 Caesium-1-1 INFO      [c.a.jira.upgrade.LoggingUpgradeService] run upgrades has finished successfully, and took 287 milliseconds to process.
2017-12-18 14:39:14,615 Caesium-1-1 INFO      [c.a.jira.upgrade.UpgradeScheduler] JIRA upgrades completed successfully
2017-12-18 14:39:14,618 Caesium-1-1 INFO      [c.a.jira.upgrade.UpgradeScheduler] Plugins upgrades completed successfully
2017-12-18 14:39:14,619 Caesium-1-1 INFO      [c.a.jira.upgrade.UpgradeIndexManager] Reindexing is not allowed after this upgrade and there is no immediate reindex requests
2017-12-18 14:39:16,463 http-nio-8080-exec-1 DEBUG   -   [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] getService bundle [com.atlassian.whisper.atlassian-whisper-plugin]
2017-12-18 14:39:19,496 Caesium-1-3 DEBUG      [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] getService bundle [com.atlassian.troubleshooting.plugin-jira]
 And JIRA has been stuck on that for 10 mn. Should I wait longer?
Rakesh Kumar
Hi Miles,
I can see this issue is marked as SOLVED. I am also facing this issue. Could you please guide me what worked for your JIRA Instance?
Regard's,
Rakesh
Miles January 7, 2019
As far as I can recall, I restarted/stopped it several times and eventually it started normally ...
Moga
December 18, 2017
JIRA could be doing an automated XML backup during the startup. If you can attach the atlassian-jira.log file here, then we can advise you further.
