×dear all i have jira server and i have more than project
one of them the backlog contain all issues listed
but the spring is always empty
Could you show us the configuration of the board please? Specifically the definitions of the columns.
Ok, great, now can you pick an issue that you think should be on the board and look at its project and status?
Ok, that's clear then. You have not got "open" mapped on to a column on the board, so issues in that status will not appear.
Map it into the "to do" column and you should then see it on the board.
Another thought, we looked at status, but I can't see the project in your screenshot. Is the issue you chose in the "Tooli" project? I have a doubt that it is not, and your board only looks at that one project.
Great, that rules out my other thought. So we need to go back to the column mapping.
Closed issues that have been completed in a sprint won't appear on the board, so we can forget that one, but let's go back to 1336 from your old screenshot - you need to map the status "open" into the "to do" column on your board to get it to appear (or possibly the in-progress column, but I don't know your process well enough to tell you. Open is usually "column 1")
Ok. So rather than dancing around with screenshots showing us parts of your config that then change, we need to nail down one fixed case.
Show us the issue, filter and column definition in full, without changing anything, and we'll be able to tell you why it is not showing
Ok, so exactly as we said earlier - the issue is in a status you have not got mapped to a column on the board.
You need to map the status "in development" into the to-do or in-progress columns on your board.
Go to the screen with the column definitions. Drag the status into the right columns for them.
HI @ahmed deraz
Whenever the ticket will create then it enters into backlog only, Once you create a Sprint, it's also an empty from backlog you need to add the issues to sprint and start working on it.
Ok, then check whether the board column name is correctly mapped with associated workflow status from board settings.
