sumup wrong totals
Αντώνης Κυριαζής
February 19, 2015
Hi there,
We use custom fields to record time and means consumption, say TEC-CONS (technical consultant), ANA-PROG (analyst programmer), PRO-MAN (project manager) and so on. The custom fields are of course number ones with two decimals. When SUMUP calculates large issue numbers  the totals are entirely wrong (some thousand man-days instead of 50-100 ones.
Can you help pls?
rgds
Benjamin_C__John__Decadis_AG_
Hey Antonis Kyriazis,
we have a new version released V1.0.1, you can update your version, and in the sumup configuration you can choose non indexed value, to get the right values. This should work for you, if not please tell us.
Cheers
Benjamin
Αντώνης Κυριαζής
February 22, 2015
Vielen Dank.
Here they are:
--- Versions ---
JIRA v6.3.11
Copyright © 2002 - 2014 Atlassian Corporation Pty Ltd.
The use of this product is subject to the terms of the Atlassian End User Agreement, unless other specified therein.
This product includes software developed by the Apache Software Foundation.
This product also includes the following libraries which are covered by the GNU LGPL license:
This product also includes code written by other third parties.
Additional details regarding these and other third party code included in this product, including applicable copyright, legal and licensing notices, are available in the "licenses" directory under the JIRA installation directory.
License Information for JIRA Plugins
JIRA Service Desk v2.1.1
Copyright © 2002 - 2013 Atlassian Corporation Pty Ltd.
The use of this plugin is subject to the terms of the Atlassian End User Agreement, unless other specified therein.
This plugin includes software developed by the Apache Software Foundation.
This plugin includes the following libraries covered by the GNU LGPL license:
  • jStyleParser(3.0)
This plugin also includes code written by other third parties.
Additional details regarding these and other third party code included in this plugin, including applicable copyright, legal and licensing notices, are available in the "licenses" directory inside the plugin.
--- sumup ---
Version: 0.6.3 Vendor: CP Systems Add-on key: com.atlassian.cps.sumUp
sumUp-admin-editor.name
(sumUp-admin-editor)
sumUp-admin-editor.description
sumUp Web Resources
(sumUp-resources)
sumUp Admin Resources
(sumUpAdminResources)
applicationProperties
jsModule
(js-issue-navigator-module)
jsModule
(js-dashboard-module)
sumUp REST API
(sum-up-rest)
The sumUp REST API
SumUp-Plugin
(sumUp)
SumUp Admin
(jira-menu-item)
Link to SumUp ConfigurationPage
Active Objects service
(aoSumUp)
Component to access Active Objects functionality from the plugin
velocityTemplateRenderer
SumUpAOConfigAoModule
The module configuring the Active Objects service used by this plugin
sumUp REST API
(sum-up-rest-filter)
The sumUp REST API
--- screendump ---
image2015-2-23 10:19:12.png
Hey rgds, can you make a non critical data-leaking screenshot? Are you using normal custom fields from type number field? Can you tell me something about your enviroment? (JIRA version, database, SumUp version) Cheers Benjamin
