Hi all,
we are using the JIRA subversion plug in. I was able to connect it to the repo and point it at folder with one file.
Commit changes appear on the JIRA tickets within an hour (which is expected due the Services setup). However when I point it to another folder in the repo that contains many files, commit messages are not shown even after 12 hours.
Is that common issue that with a big repo that the integration is slow due to initial indexing ?
Any other suggestions ?
Lior
This is fresh install of this plug in. Also the second the repo does not contain the first one but both are just folder in the same repo.
Is there a way to check if the indexing task is currently running or not?
I will try removing the files you mentioned.
It is more common that indexing task dies and you need to restart it. It is also possible that the first index logically covered the second repository if they are in the same the svn repository (ie just different directories). Assuming the index task is still alive, then try reindexing from the beginning by removing the files named in the upgrade documentation.
https://ecosystem.atlassian.net/wiki/display/SVN/Subversion+JIRA+plugin
