system info REST call
Muhammad Awan December 7, 2018
Hello all -
i am trying to monitor the JIRA platform and want to make REST calls to get information - my jira version is 7.12 -
Question - where can i get a list of calls that i can mage to get system information
e.g -- http://<server-ip>:<port>/resr/------------
Aakash T December 10, 2018
@Muhammad Awan,
You can use serverinfo rest API but it returns very limited information about JIRA server. At the moment, for detailed system info one ticket is already been tracked here.
Unfortunately, you can not get very much detailed result from any REST end point.
Hope this helps.
Thanks.
Muhammad Awan December 10, 2018
Thanks for the response - the data that i want is system status - so one check is
curl -iv http://192.168.XXX.XX:8080/rest/troubleshooting/1.0/check/
are there similar checks that i can make to get JVM memory from system info
Michael Aglas
you can use this one: https://marketplace.atlassian.com/apps/20909/javamelody-monitoring-plugin?hosting=server&tab=overview
it allows you to request info about it JVM via <jira baseurl>/monitoring?format=json&part=jvm
Like Trung Pham likes this
Alexey Matveev
December 7, 2018
You can find the list of available Rest Api calls here:
https://developer.atlassian.com/cloud/jira/platform/rest/v3/?utm_source=%2Fcloud%2Fjira%2Fplatform%2Frest%2F&utm_medium=302#gettingstarted
If it is not available there, what you are looking for, then there is no public API to get his info.
