timeline view
Glenn Guit January 16, 2025
I don’t see the timeline icon. I created a project with a Kanban board. Is it possible to activate the timeline view? I would like to create a Roadmap view and I believe this would be possible with the timeline view.
2 accepted
4 votes
Jack Brickey
Hi @Glenn Guit , what type of project are you using? Can you go to Project setting and see if "Features" option is in sidebar and if so enable Timeline?
Hi Jack Brickey, thanks for your fast reply. I don't see "Features" in project settings.
Jack Brickey
thanks @Glenn Guit . as you determined this is Data Center so not available.
Manoj Gangwar
Hi @Glenn Guit Welcome to the community!
Please follow the below doc to enable the timeline.
https://support.atlassian.com/jira-software-cloud/docs/enable-and-disable-the-timeline/
Hi Manoj GangwarThanks for your fast reply. I believe I do use the Jira Software Data Center, because the URL doesn’t have the Cloud URL. Therefore, no timeline view is available. If this is correct, then I need to find another solution to create a roadmap with quarterly columns.
Like Manoj Gangwar likes this
