unable to create issue in jira through jira rest api in javaScript
Kavitha Yeleti March 8, 2018
I want to create an issue in JIRA via REST API call with javaScript code.. When I executed the below code there is no error, but also no issue is created in JIRA. I have used the same JSON code to create issue in JIRA with "CURL" command and it worked succesfully. But I failed to create with this sample code below.Can anyone please help on this.
Note: consider credentials and URL is correct.
<html>
<head>
<meta charset="ISO-8859-1">
<title>Create Issue</title>
<script type="text/javascript">
function createIssue() {
    var xhttp = new XMLHttpRequest();
     var createJson ='{  "fields": {
         "project":{
             "key": "LPS"
             "summary": "creting issue",
             "description": "creating issue from client isde",
             "issuetype": {
                          "name": "Task"
             "priority": {
                          "id": "2"
             "assignee":{
                          "name": "abcd"
    xhttp.onreadystatechange = function() {
    if ((xhttp.readyState==4) {      document.getElementById("demo").innerHTML =xhttp.responseText;
    xhttp.open("POST", "URL",true);    xhttp.setRequestHeader("Content-type", "application/json");    xhttp.setRequestHeader("X-Atlassian-Token", "nocheck");    xhttp.setRequestHeader('Authorization', 'Basic '+btoa('username:password'));
    xhttp.send(createJson);
</script>
</head>
<body>
<h2>Create Issue</h2>
<button type="button" onclick="createIssue()">createIssue</button>
<p id="demo"> </p>
</body>
</html>
Alexey Matveev
March 8, 2018
What do you mean that there is no error? Do you get 200 status code? If there is no error then you should get the key of the created issue.
Kavitha Yeleti March 9, 2018
Hey, Am not getting any response from the server and the issue is not getting created in JIRA
Alexey Matveev
March 9, 2018
If you make a request to a server then you must get a response. Try to use Developer Tools in your browser.
not sure why its not responding and i could add the comment and edit the existing fields of an issue with the same sample code but only this one(creating issue) is not working
It worked for me, its a syntax error. Thank you!
Karthigaipreethi karuppanan
September 30, 2021
Can you share the updated code. Am also trying to update JIRA issues using javascript..
