we have our own plugin which was working earlier and stopped working after Jira software upgrade to 8.4.2 server. I get the following error message and the plugin doesn't deploy while server startup. Your help is much appreciated.
2019-11-06 00:51:10,115 localhost-startStop-1 ERROR [c.a.plugin.loaders.ScanningPluginLoader] Unable to deploy plugin 'com.example.proaction.projectinfo' from 'Unit: C:\D-Drive\asop_workspace\proaction-project-view-plugin-for-jira\project-info\target\jira\home\plugins\installed-plugins\projectinfo-1.0.8-SNAPSHOT.jar (1572981099922)'.
2019-11-06 00:51:10,119 localhost-startStop-1 ERROR [c.a.plugin.loaders.ScanningPluginLoader] Because of the following exception:
java.lang.NullPointerException
at com.atlassian.plugin.osgi.factory.transform.stage.HostComponentSpringStage.addHostComponentsUsedInSuperClasses(HostComponentSpringStage.java:235)
at com.atlassian.plugin.osgi.factory.transform.stage.HostComponentSpringStage.findUsedHostComponents(HostComponentSpringStage.java:220)
at com.atlassian.plugin.osgi.factory.transform.stage.HostComponentSpringStage.execute(HostComponentSpringStage.java:69)
at com.atlassian.plugin.osgi.factory.transform.DefaultPluginTransformer.transform(DefaultPluginTransformer.java:140)
at com.atlassian.plugin.osgi.factory.OsgiPluginFactory.createOsgiPluginJar(OsgiPluginFactory.java:307)
at com.atlassian.plugin.osgi.factory.OsgiPluginFactory.create(OsgiPluginFactory.java:224)
at com.atlassian.jira.plugin.MasterPluginFactory.create(MasterPluginFactory.java:73)
at com.atlassian.plugin.loaders.ScanningPluginLoader.deployPluginFromUnit(ScanningPluginLoader.java:145)
at com.atlassian.plugin.loaders.ScanningPluginLoader.loadAllPlugins(ScanningPluginLoader.java:90)
at com.atlassian.plugin.loaders.PermissionCheckingPluginLoader.loadAllPlugins(PermissionCheckingPluginLoader.java:28)
at com.atlassian.plugin.manager.DefaultPluginManager.lambda$earlyStartup$3(DefaultPluginManager.java:539)
at com.atlassian.plugin.manager.PluginTransactionContext.wrap(PluginTransactionContext.java:63)
at com.atlassian.plugin.manager.DefaultPluginManager.earlyStartup(DefaultPluginManager.java:523)
at com.atlassian.jira.plugin.JiraPluginManager.earlyStartup(JiraPluginManager.java:119)
at com.atlassian.jira.component.pico.ComponentManager$PluginSystem.earlyStartup(ComponentManager.java:669)
at com.atlassian.jira.component.pico.ComponentManager.earlyStartPluginSystem(ComponentManager.java:238)
at com.atlassian.jira.upgrade.PluginSystemLauncher.start(PluginSystemLauncher.java:45)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$postDbLaunch$2(DefaultJiraLauncher.java:145)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:301)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:196)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:137)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$start$0(DefaultJiraLauncher.java:104)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:31)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:102)
at com.atlassian.jira.startup.LauncherContextListener.initSlowStuff(LauncherContextListener.java:154)
at com.atlassian.jira.startup.LauncherContextListener.initSlowStuffInBackground(LauncherContextListener.java:139)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:101)
... 8 filtered
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Here's my pom.xml
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.example.proaction</groupId>
<artifactId>projectinfo</artifactId>
<version>1.0.8-SNAPSHOT</version>
<organization>
<name>example</name>
<url>http://www.example.com/</url>
</organization>
<packaging>atlassian-plugin</packaging>
<name>projectinfo</name>
<description>This is the com.example.proaction:projectinfo plugin for Atlassian JIRA.</description>
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
</dependency>
<dependency>
<artifactId>jira-core</artifactId>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
<scope>compile</scope>
</dependency>
<dependency>
<artifactId>atlassian-spring-scanner-runtime</artifactId>
<scope>runtime</scope>
</dependency>
<dependency>
<groupId>com.atlassian.inject</groupId>
<artifactId>atlassian-inject</artifactId>
<version>1.0.0</version>
</dependency>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.2.2-atlassian-1</version>
</dependency>
<dependency>
<groupId>org.apache.httpcomponents</groupId>
<artifactId>httpclient</artifactId>
<version>4.1.1</version>
<scope>test</scope>
</dependency>
<!-- https://mvnrepository.com/artifact/com.atlassian.sal/sal-api -->
<dependency>
<groupId>com.atlassian.sal</groupId>
<artifactId>sal-api</artifactId>
<version>3.0.7</version>
</dependency>
<!-- https://mvnrepository.com/artifact/org.apache.velocity/velocity -->
<dependency>
<groupId>org.apache.velocity</groupId>
<artifactId>velocity</artifactId>
<version>1.7</version>
</dependency>
<dependency>
<groupId>org.apache.logging.log4j</groupId>
<artifactId>log4j-api</artifactId>
<version>2.12.1</version>
</dependency>
<!-- https://mvnrepository.com/artifact/com.atlassian.crowd/embedded-crowd-api -->
<dependency>
<groupId>com.atlassian.crowd</groupId>
<artifactId>embedded-crowd-api</artifactId>
<version>2.8.0-OD-6-JIRA-05</version>
</dependency>
<!-- https://mvnrepository.com/artifact/com.atlassian.plugins/atlassian-plugins-webfragment -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-webfragment-api</artifactId>
<version>4.1.0</version>
</dependency>
<!-- https://mvnrepository.com/artifact/com.atlassian.plugins/atlassian-plugins-core -->
<dependency>
<artifactId>atlassian-plugins-core</artifactId>
<version>2.6.0</version>
</dependency>
<!-- https://mvnrepository.com/artifact/com.atlassian.jira/jira-projects-api -->
<dependency>
<artifactId>jira-projects-api</artifactId>
<version>4.1.13</version>
</dependency>
<dependency>
<groupId>javax.servlet</groupId>
<artifactId>servlet-api</artifactId>
<version>2.5</version>
</dependency>
<!-- https://mvnrepository.com/artifact/velocity-tools/velocity-tools-generic -->
<dependency>
<groupId>velocity-tools</groupId>
<artifactId>velocity-tools-generic</artifactId>
<version>1.4</version>
</dependency>
<dependency>
<groupId>org.json</groupId>
<artifactId>json</artifactId>
<version>20090211</version>
</dependency>
<!-- https://mvnrepository.com/artifact/com.google.guava/guava -->
<dependency>
<groupId>com.google.guava</groupId>
<artifactId>guava</artifactId>
<version>r05</version>
</dependency>
<!-- https://mvnrepository.com/artifact/org.apache.lucene/lucene-core -->
<dependency>
<groupId>org.apache.lucene</groupId>
<artifactId>lucene-core</artifactId>
<version>8.1.1</version>
</dependency>
</dependencies>
<build>
<defaultGoal>package</defaultGoal>
<plugins>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>jira-maven-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
<startupTimeout>1200000</startupTimeout>
<shutdownTimeout>900000</shutdownTimeout>
<instructions>
<Export-Package>
</Export-Package>
<Import-Package>org.springframework.osgi.*;resolution:="optional",
org.eclipse.gemini.blueprint.*;resolution:="optional",
com.atlassian.sal.api;version="0.0.0";resolution:="optional",
com.atlassian.plugin.spring.scanner.annotation.*;version="0.0.0";resolution:="optional",
com.example.proaction.projectinfo;version="0.0.0";resolution:="optional",
com.atlassian.inject;version="0.0.0";resolution:="optional",
*;</Import-Package>
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<scannedDependencies>
<dependency>
<artifactId>atlassian-spring-scanner-external-jar</artifactId>
</dependency>
</scannedDependencies>
<verbose>false</verbose>
</configuration>
</plugin>
<plugin>
<artifactId>maven-compiler-plugin</artifactId>
<version>3.1</version>
<configuration>
<fork>true</fork>
<executable>C:\Program Files\Java\jdk1.8.0_91\bin\javac.exe</executable>
</configuration>
</plugin>
</plugins>
</build>
<properties>
<jira.version>8.4.2</jira.version>
<amps.version>8.0.2</amps.version>
<atlassian.spring.scanner.version>1.2.13</atlassian.spring.scanner.version>
<quick.reload.version>3.0.0</quick.reload.version>
<maven.compiler.source>1.8</maven.compiler.source>
<maven.compiler.target>1.8</maven.compiler.target>
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<maven.test.skip>true</maven.test.skip>
</properties>
</project>
Thanks in advance for your time.
-Kumar
I run into the same issue followed by
com.atlassian.upm.spi.PluginInstallException: Unknown error, plugin not installed
at com.atlassian.upm.core.install.AbstractPluginInstallHandler.installArtifact(AbstractPluginInstallHandler.java:122)
The cause was in
META-INF/versions/9/module-info.class
I excluded it with following workaround
<plugin>
<artifactId>maven-dependency-plugin</artifactId>
Workaround to exclude module-info.class from META-INF/versions/9 that is cause of
"com.atlassian.upm.spi.PluginInstallException: Unknown error, plugin not installed"
<configuration>
<excludes>atlassian-plugin.xml, META-INF/MANIFEST.MF, META-INF/*.DSA, META-INF/*.SF,META-INF/versions/9/*.class</excludes>
</configuration>
</plugin>
Any other work around?
Have you been able to resolve this problem? I got the same error.
