Sign up Log in
uninstall - file in jira
Vickey Palzor Lepcha
April 20, 2018
What is the use of the file : uninstall .
Is it triggered when we run an uninstall?
What if I run the file manually
Pedro Souza
April 24, 2018
Hi Vickey!
Could you please clarify the complete file path of this "uninstall" file that you mentioned?
I just checked in a clean 7.9 installation and I was not able to find any file named "uninstall" in my installation or bin folder.
I would like to have the complete file path, so I can make sure to check the exact same file and clarify to you the purpose of this file in the application files.
Pedro Souza.
April 24, 2018
Its there with all directories ../conf  ../bin  ../lib ../jre and so on.
-rwx------ 1  uninstall
drwxr-xr-x 4  jre
drwxr-xr-x 2 lib
drwxr-xr-x 3 conf
drwxr-xr-x 3 bin
drwxr-xr-x 3 work
drwxr-xr-x 2 logs
drwxr-xr-x 4 temp
Pedro Souza
April 24, 2018
Hi Vickey,
Odd, I don't have such file in my regular installations.
Could you please run an "ls -lth" to gather more details from your installation folder including this file and attach the output, and also try to open the file with "vi" to see the content?
Pedro Souza.
Upcoming Jira Events
