It seems that jira osuser has been removed since version 5.0.
Now how can I get user-related objects as I did in v. 4.4.4 via importing com.opensymphony.user.User?
Thanks.
You can try using -
com.atlassian.crowd.embedded.api.User;
Since com.opensymphony.user.User is deprecated.
You can mark the answer as correct if you find it useful :)
You can try using -
